Z is starting to squeak, what could be squeaking?
Old Feb 18, 2008 | 12:31 AM
JJ350's Avatar
JJ350
Default Z is starting to squeak, what could be squeaking?
I have recently noticed a light squeaking sound coming from my Z. I noticed it when driving with my windows down, and the squeak seems to be related to a part that is rotated since it is short yet consistent with my speeds. I mostly notice it when I am just cruising around, usually when I am not braking and it occurs most often when taking left turns for some reason.
Not related yet also occurring, my drivers side door has been squeaking when I open it. I am guessing that it probably just needs lubrication, but I just want to make sure and know how.
Old Feb 18, 2008 | 06:24 AM
Squeaking is indicative that something is worn. If it is the door hinges, a little WD40 will cure the problem.
If you suspect a suspension component then a mechanic will have to get under the car for a inspection.
Old Feb 18, 2008 | 07:45 AM
marco_mendoza's Avatar
marco_mendoza
What year and how many miles?
Old Feb 18, 2008 | 08:42 AM
350ZTheStandard's Avatar
350ZTheStandard
Care to give us more hints/information on the area the sound is coming from, is this intermittant, any other important details you are wanting us to guess about would be great.
Old Feb 18, 2008 | 09:35 AM
JJ350's Avatar
JJ350
The sound is intermittent since I don't always have the squeak. like I said it seems to occur when I am cruising straight at times, and mostly when I am taking left turns for some reason. My Z is in my sig (06 GT auto, about 26k miles with original brakes). So maybe it is my brakes since I am usually never applying the brakes when I hear the squeak. The only other way I could describe it more is that it is a light squeak, and it is short but consistent with my speeds when it occurs. Probably nothing major, but I still just want to get to the bottom of this since I don't like having a squeaky Z.
Maybe I should bring it in to the dealer and tell them about it, and hopefully they can fix it? Maybe I should have them lubricate the door too.
Old Feb 18, 2008 | 10:28 AM
Ztalker's Avatar
Ztalker
most likely your brakes(26k miles is due for replacement).
Old Feb 18, 2008 | 10:29 AM
JJ350's Avatar
JJ350
That is what I was thinking, I guess like it is off to the dealer for me then...
Old Feb 18, 2008 | 10:30 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
waiting on davidv's comment
Old Feb 18, 2008 | 11:14 AM
orangeflash's Avatar
orangeflash
Old Feb 18, 2008 | 01:23 PM
EricChan's Avatar
EricChan
Banned for NON PAYMENT
I also Had a light high pitched squeak comming from the front end of the car. I couldn't replicate it at the dealer. Anyhow, I ended up having to change my brake pads two days ago and alas... NO MORE SQUEAK. It wasn't the kind of squeak you get when engaging your brakes but it only came around when i was in 2500 to 3500 rpm range and then it went away. and would come back occasionally, never heard it when breaking and always heard it coming out of a turn. CHECK your brakes and while your at it your rotors and see whats left because the indicator was what was rubbing occasionally on mine.
edit: I have a 2003 Track just hit 30k and replaced all brakes.
Old Feb 18, 2008 | 06:56 PM
JJ350's Avatar
JJ350
Well damm, that sounds just like what I am experiencing. Do brembo's tend to wear out a little quicker than the standard brakes? Anyways I am pretty convinced that this must be related to my brakes by now, I guess like I will check if they have to be replaced and hopefuly that fixes this.
Also, where would I want to apply the WD40 for my henge squeak?
Old Feb 18, 2008 | 07:13 PM
The top and bottom hinges.
Old Feb 20, 2008 | 10:05 PM
itsjiggajames's Avatar
itsjiggajames
My z is starting to get intermittent sounds, but more like half squeaky half "TSS TSS TSS" sounding.. dealer says it's normal, so I guess I have to take care of this myself. It is really annoying. Does anyone know if the grease they use to quiet brake pads will work?
Old Feb 21, 2008 | 05:33 AM
Are you talking about caliper grease? The grease that you put between the caliper and pad? I would not install pads without using grease.
Old Feb 21, 2008 | 05:56 AM
brickyardgreg's Avatar
brickyardgreg
dont use wd40 on the hinge. grease it. wd40 will cut the little grease you do have in there then when the wd dries up it will squeek like a beotch
Old Feb 21, 2008 | 11:57 AM
isaacbush's Avatar
isaacbush
yea that should do it
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Dymsi
Sep 29, 2015 11:32 AM
