30K service quote...sound right?
Procedures Included:
- Adjust clutch - $157.50
- Adjust idle speed - $89.00 if our computer has the capabilities.
- Cooling system flush - $189.50
- Adjust rear brakes, if needed - Not applicable on rear disc brakes.
- Lubricate chassis - Free with oil change
- Change engine oil and filter - $29.95
- Inspect chassis & suspension - Free with oil change
- Check air conditioner operation - $192.00
- Inspect & top off all fluid levels - Free with oil change
- Inspect & adjust all belts - Free with oil change
- Inspect & adjust emissions, if needed - $315.00 to get an emissions specifications read-out, but probably unnecessary with a low mileage car.
- Check plug wires, cap & rotor - Free with oil change
- Inspect cooling system - Free with oil change
- Inspect front & rear brakes - Free with oil change
Working for a dealership, the real reason they want you to do that is so they can sell more services to you, tires, brakes...those are the big ones, and the flushes, they get giddy over flushes, you'll pay for that service and then they'll come back and be like..well did ya know, we're having a special today...and you leave the dealerships $800-$2000 poorer...lol
Aye the 30,000 mile service is an expensive one. Heres what I did. I changed the tranny, differential, and engine oils. Replaced spark plugs. I was going to flush the coolant system but I read somewhere it was optional. Changed the wiper blades. Cleaned/recharged pop charger filter. The only thing I needed help with was getting the tires swaped. Theres a list of things that need to be done for the 30k i think its in your manual not sure, it tells you whats mandatory, recommended or optional.
oh btw whenever you take your nissan in for service and ask for the full 21pt inspection or whatever they call it now a days they will NOT check for nails in your tires... -.-
