Major Z Issue - Pics Inside
Old Feb 22, 2008 | 12:19 PM
RedBullRR's Avatar
RedBullRR
30 Bucks to diagnose a problem isnt so bad. I also have the extended gold warranty. Everytime I bring my car to the shop they want a 95 diagnostic fee. Atleast there not asking you for that. I can understand why they want you to pay for the oil. Its a cheap blow for them but whatever. Your almost at 100K, and really all you have is a leaky valve cover. In my acura integra I had to change that **** every oil change.
Old Feb 22, 2008 | 03:26 PM
Rommy's Avatar
Rommy
Originally Posted by JETPILOT
You need new valve cover gaskets. They are leaking.
JET
Yep. Had a Toyota Supra, same thing happened.
Old Feb 27, 2008 | 05:50 PM
bjr's Avatar
bjr
My valve cover gaskets on my last car started leaking at 40,000 miles or so. I spent the $50 or so on the gaskets, spent 5 hours in the garage and replaced them myself. Put another 120,000 miles on it and traded it in on the Z. Never had a problem again. I didn't blame Ford for it and I didn't complain about it. The factory seals just didn't hold up Don't know how you really would gauge what is the expected lifetime of a seal like that. Some people never have a problem and others do. I am not surprised with my bad luck
If that is all it is that does not warrant a new motor. And it sure is not the end of the world. The only way to see if you have any motor problems is to let them do the compression test they want for $30 or spend several hundred dollars to fix the valve covers and see if you still burn oil! I'd let them proceed and calm down about it. Good luck. Keep us posted becuase I've never seen anyone else complain about valve cover leaks.
Off to see who has valve cover leaks and the labor to do it so I'm prepared if it ever happens to me!
Old Feb 27, 2008 | 06:13 PM
bjr's Avatar
bjr
Geez, this sucks...
https://my350z.com/forum/showthread....t=valve+covers
If it's true there are some automotive engineers that need to be taken out back and shot. I swear most of the new ideas in cars that I have seen in the last 10 years absolutely suck.
OP - I'm starting to feel a little bit of your pain now, but probably not for the same reasons. Good luck again, hope that warranty thing you bought covers something but it still would be normal wear and tear.
I found two other posts with no repsonses and don't have time at home to go through the other 8 pages that may or may not have a match... maybe tomorrow...
Old Feb 27, 2008 | 08:36 PM
toy4two's Avatar
toy4two
sounds like the service advisor was trying to help you get a whole new engine and using the recently released oil consumption test which if you fail = new engine, instead you acted the fool and I doubt this guy is going to try to hook you up at all. You really blew it, a $2000 engine all because you moaned about $30, good going.
Old Feb 28, 2008 | 09:46 AM
bjr's Avatar
bjr
Sorry I was wrong. I posted a link to seals that were actually for the valves themselves. I finally noticed that 24 are required for the car. Nevermind.
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
