Moisture in the headlights...
Old Jun 22, 2003 | 07:14 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Arrow Moisture in the headlights...
I got my car on the 17th and since the 1st night moisture was collecting in the headlights. I inquired with someone from Nissan and was advised that it is normal, that the headlights were designed to breathe and moisture would collect and then dissipate again. Is this accurate or just BS? Hard to belieive, I observed many others without it. Let me know, thnx.
Old Jun 22, 2003 | 09:21 AM
freshzz's Avatar
freshzz
Angry headlight moisture
Absolutely inaccurate!
Please contact Nissan Consumer Affair at 800-647-7261 and tell them your dealer shrugged you off with such incompetant answer.
GET IT FIXED!
Old Jun 22, 2003 | 10:24 AM
Selski12's Avatar
Selski12
Moisture is there for about a couple weeks to a month. Happens to most, as well as mine. It goes away.
If it does not, then I would examine the housing to see if there are any cracks and such, then take it to the dealer.
Old Jun 22, 2003 | 10:41 AM
Stone Z's Avatar
Stone Z
I had moisture the first two days.....none since. It will go away.
Old Jun 22, 2003 | 01:29 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
K thnx for the tips, ill give it a couple weeks and see what happens
Old Jun 24, 2003 | 03:24 PM
julian's Avatar
julian
yeah, it'll probably go away, but you can probably get it changed under warranty if you fight hard enough. moisture means there's a leak in the seal somewhere.
Old Jun 24, 2003 | 08:27 PM
s9am_me's Avatar
s9am_me
still got mine.. but i'm finding them less frequent and not as much as the first time i had it
Old Jun 24, 2003 | 10:48 PM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Yea, one headlight(left) is worse than the other for me. Its not a big deal it just bothers me, and after i wash the car there is moisture there f0r a good amount of time.
Old Jun 25, 2003 | 01:24 PM
MadMax76's Avatar
MadMax76
In my old car I took a drill with a very very small tip (about 1-2mm in diameter) and made a hole on the very bottom of the light. I used to collect moisture all the time, but right after I drilled the holes everything went away and you would never find the hole in them either.
Old Jun 25, 2003 | 02:50 PM
dr_gallup's Avatar
dr_gallup
The 350Z headlight cover is NOT sealed and moisture inside may be normal. The more often you use your lights the less likely you will see it. A sudden decrease in ambient temperature will bring it back. Excessive amounts of water may indicate a leak and the need for repair.
See TSB New Vehicle Service Hints NTB02-112 in the TSB thread.
etkms
Jun 19, 2022 06:30 PM
zeebeda
Jan 10, 2006 03:38 PM
bmxox
Nov 12, 2005 03:42 PM
bman_350Z
Feb 23, 2005 10:44 AM
dskang100
Sep 11, 2004 12:38 AM
