Starting issue
Old Mar 23, 2008 | 07:26 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Default Starting issue
Ok, when i started my car somehow my car started shaking little and RPM was dropping. ( it usualy happens when cold weather so i have to kick clutch when i start a car. )
But today this weird thing happend. it started shaking little/ making a weird noise and than barely started.
and smell something burning for a while.
but smell it went away.
i'm thinking maybe spark plugs?
i'm at 43K now.
anyone can explain ?
Old Mar 23, 2008 | 08:21 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
bump!
Old Mar 23, 2008 | 08:29 PM
Teufel's Avatar
Teufel
From the little I know. Sparks are good for 100K miles.
Old Mar 24, 2008 | 07:06 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^Thanks
i remember it was 105k something.
Old Mar 25, 2008 | 07:59 AM
1sikz31's Avatar
1sikz31
If you let your plugs to stay in the heads for 100,000 miles
MY BETS are the plugs would weld themselves in the cylinder head.
Spent the extra money, and change your plugs at 60,000 miles for preventive maintenance.
Old Mar 25, 2008 | 03:28 PM
Frank@MtroNiss's Avatar
Frank@MtroNiss
Default starting problem
make sure that the throttle chamber is not gummed up or dirty..try taking the intake boot off and use some throttle chamber cleaner,be sure to clean the front and back of the butterfly and around the small vacuum hole in the chamber..dont over do it on the spray.
Old Mar 25, 2008 | 05:08 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
my spark plugs comming in tommorow
sometime next week when i have time i will replace them on.
i will see how it goes from there.
thanks for info guys
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
