Oil on spark plug...... Help!
Old Mar 27, 2008 | 03:51 AM
ChrisCJ99's Avatar
ChrisCJ99
Default Oil on spark plug...... Help!
So I just recently went FI an put on a TN kit about 2 weeks ago. After a week I got a SES light. Car runs good and strong. I ran the codes and it ranged anywhere from a 1274, 1284 and a random misfire. I was told to change my spark plugs to one step colder. So when I went to change out the last plug (driver side closest to the steering wheel) I noticed the BOTTOM part of the spark plug was wet with oil.... I was told that "plastic tube" and gasket just need to be replaced....
My question is, has anyone ever found oil on their spark plugs and, if so, what was the problem and how did you fix it?
Old Mar 27, 2008 | 03:53 AM
Sean's Avatar
Sean
time for a compression check.
Old Mar 27, 2008 | 04:05 AM
ChrisCJ99's Avatar
ChrisCJ99
So how do you do a compresssion check?
And if it IS a blown ring, how expensive is something like that??
Old Mar 27, 2008 | 04:14 AM
Sean's Avatar
Sean
you will need a gauge, or take it to someone to do it.
If it is a ring gasket it will be cheap. You can do it yourself.
If it's a piston ring.....expensive.
Old Mar 28, 2008 | 06:39 PM
j.arnaldo's Avatar
j.arnaldo
Stop scaring the ignorant n00bies!
Old n00bie from Puerto Rico.
Old Mar 28, 2008 | 06:54 PM
ChrisCJ99's Avatar
ChrisCJ99
Haha! I found that it was a small leak in the valve gasket cover... So nothing TOO threatening
Old Apr 1, 2008 | 04:54 PM
syndacit's Avatar
syndacit
I just did a spark plug change, and I found oil in the exact same place. closest to steering wheel.
Old Apr 2, 2008 | 04:22 AM
ChrisCJ99's Avatar
ChrisCJ99
So did you try changing your valve cover gasket? I'd really like to see a DIY on changing a valve cover gasket (with pics)
Old Apr 2, 2008 | 04:36 AM
Jay'Z's Avatar
Jay'Z
I had the same issue.. I hope it goes away.. lol
Old Apr 2, 2008 | 05:32 AM
silvaZ32's Avatar
silvaZ32
its the valve cover. you need to replace the valve covers i have the same problem.
Old Apr 2, 2008 | 05:35 AM
ChrisCJ99's Avatar
ChrisCJ99
So can anyone provide a link on some DIY's or instructions (with pics) on how to do this?? Ive heard its pretty easy, I just wanna do it right...
Old Apr 2, 2008 | 05:43 AM
blasian's Avatar
blasian
Check out the service manual and it will show you the way. I just took mine off a few weekends ago.
Old Apr 2, 2008 | 08:53 AM
syndacit's Avatar
syndacit
well, I want to go FI with vortech. So I will be needing to replace it because of safety reasons to the engine.
When I get time, I could try and make a DIY, no promises though.
Old Apr 2, 2008 | 10:45 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
i just got back from my friend's shop, just replaced regular NGK spark plugs.
i found oil on same spot. well we used vacume it and clean inside of hole.
i'm guessing that i have to replace O ring in soon or later.
* i have 45K milies on.
Old Apr 2, 2008 | 11:26 AM
Jay'Z's Avatar
Jay'Z
This seems so common...........
Old Apr 2, 2008 | 11:28 AM
blasian's Avatar
blasian
Agreed...
Figured I'd see if I can fix it rather than paying hundreds on new valve covers for it to do the same thing.
Old Apr 2, 2008 | 11:54 AM
ChrisCJ99's Avatar
ChrisCJ99
how do you plan on fixing it?
Old Apr 2, 2008 | 11:55 AM
blasian's Avatar
blasian
I'm a cheap bastid. I RTV'd the seals instead of replacing the entire valve cover. I figured why pay $400-500 on valve covers if it will probably start leaking again
I haven't checked to see if there is more oil there though
Old Apr 2, 2008 | 12:01 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ true.
Old Apr 2, 2008 | 01:44 PM
ChrisCJ99's Avatar
ChrisCJ99
but don't you only have to replace the valve cover gasket?
