Automotive Electrical Expertise needed
Below is a picture of a wire plug that connects to the radiator fan of my Z. As you can see its f&*ked up. Something like a critter has ate through the wires and now I must replace the wires but this one is a little tricky cause its so close to the end of the plug. Is it possible to get a new plug like this or is there a tool to remove the wires.
In all due respect... little chance of a match up. I have taken many apart if I had to and rewired. Its takes a little know how. If they put it together, It can be taken it apart and modded. Another bet is get online and find a wrecked one that you can have cut at 8" or so.
Looms at the dealer are HIGH unless it is less than a foot or so
Originally Posted by Eazzy
For the time being, there is no reason that they cant be soldered and shrink tubed, deleting both plugs
I had seen on one site there was this tool that you could use to push the wires out of a plug but i am not sure if it would work with this one.
Just had an idea that I might delete these plugs and go with some other ones. Anybody do this or what you think about that?
My point was---If there is a will there is a way. It would just depend on the level of abilitys. Without going out and looking at it, I was just throwing options. Seems to me that is a rather long loom that runs through eyelets on the fan shroud, so your simplest fix would be to find one off another Nissan (not just a Z) and splice it in
Originally Posted by SponGer
You can use bullet or spade (male and female) connectors on both ends if you cannot find a replacement plug.
Originally Posted by 350zlmtd
Sorry eazzy I misunderstood ya. Does nissan only use these kind of connectors or they pretty common in other cars?
I just looked at mine and there is a short extention that plugs directly into the fan----That Male may very well be the same as the Male that you have probs with ---so if you just get the short pigtail , that may be your cut and splice piece
Originally Posted by Tim@Performance
You don't have to by the entire harness. We have a cabinet full of all kinds of different connectors. They are aftermarket but a better solution if yours can not be fixed.
Is it a four pin/four wire connector? I can't see from the pic and don't feel like going to find a z on our lot.
