The "Missing" headlight fuses
Old Jul 1, 2003 | 08:06 PM
REDZED's Avatar
REDZED
Talking The "Missing" headlight fuses
Well after a looong search it seems there is a EPDM (Electronic Power Distribution Module) hidden in behind/beside the battery that controls the "high current" systems and has the relays/fuses for the headlights ( and other stuff )
This system is CAN controlled so its a smart fusebox but doesn't seem to be well known. Given the fact that i want to do a headlight wattage upgrade i will check the relays etc very carefully as this EPDM is probably verrrrry expensive if it gets stuffed.
Still have to investigate the wiring etc.
Old Jul 1, 2003 | 08:49 PM
REDZED's Avatar
REDZED
Default More on CAN bus system
Seems quite a bit of the Z electronics is controlled by the CAN bus system. If you want to know more about CAN goto http://www.can.bosch.com/
It gets a bit heavy in spots but might explain some of the mysteries.
Miguel Albanez
Oct 17, 2022 10:13 AM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
kyin
Oct 15, 2015 05:54 AM
JGee450
Sep 30, 2015 04:32 AM
