high pitched noise in cabin of car?
Old Apr 17, 2008 | 06:44 AM
fatinma's Avatar
fatinma
Default high pitched noise in cabin of car?
Brand new '08 base model, 6spd.
With the radio turned off, as soon as I turn the car on, I hear this very very quiet, but still audible high pitched noise. Almost similar to what you would hear from the old tube television (not sure if anyone remembers,but I remember hearing this very high pitched sound, and if you turn your head slightly, it might go away).
It really isn't that noticeable all the time, but has anyone else noticed this.
Old Apr 17, 2008 | 06:53 AM
Sean's Avatar
Sean
does the nosie change if you step on the gas? A higher faster pitch?
Old Apr 17, 2008 | 07:05 AM
350zshopper's Avatar
350zshopper
My 07 makes that noise. You can really notice it if you turn the key "on", but don't crank the starter. It sounds like the fuel pump to me.
Old Apr 17, 2008 | 07:07 AM
Spork's Avatar
Spork
Can it be the ground for the stereo?
Or is it just the fuel pump?
Old Apr 17, 2008 | 07:36 AM
fatinma's Avatar
fatinma
I haven't noticed if the noise changes when i step on the gas, but it might be due to the interior noise in the cabin increasing when I do step on the gas. I will try it out later when I am in the parking lot.
Someone mentioned the fuel pump. I don't know how I would check that, but if that is something I can check, how would I go about doing that?
Thanks.
Old Apr 17, 2008 | 07:37 AM
fatinma's Avatar
fatinma
I will try that out later and see if the noise is more noticeable with only the key turned to "on".
Old Apr 17, 2008 | 07:38 AM
Clipdin's Avatar
Clipdin
SHIFT_happens
I hear the same thing in my 07. Not every day though.
nothix's Avatar
nothix
I hear the same thing every once in a while.
Seems to be coming from the passenger rear
Old Apr 17, 2008 | 07:45 AM
Neo_B's Avatar
Neo_B
its the radio, when i turn my radio off it goes away...
Old Apr 17, 2008 | 07:47 AM
TheOtherRob's Avatar
TheOtherRob
I thought I was the only one. I hear it most of the time when the car is quiet and running. I can turn of everything and be on the freeway and still hear it. And you described it perfect, like a tube tv turned on with no volume just the high frequency.
Old Apr 17, 2008 | 07:56 AM
fatinma's Avatar
fatinma
I hear it without the radio being on.
I am just relieved that other people hear this as well and its not just me.
Old Apr 17, 2008 | 07:57 AM
terrasmak's Avatar
Every once and a while i get that if my ignition is on and the car isnt started.
Old Apr 17, 2008 | 08:01 AM
TheOtherRob
OP, mine is an 08 also if that makes you feel better. Sometimes it gets really annoying. Too bad there is really nothing you can do about it since a dealer would clame they dont hear anything...
Old Apr 17, 2008 | 10:04 AM
Brrcats's Avatar
Brrcats
I know exactly what youre talking about but thankfully have never heard it in my Z, i focus too much on the rear axle clicking. which now reminds me to take it in to get that fixed.
Old Apr 17, 2008 | 10:27 AM
fatinma's Avatar
fatinma
What are you doing in your Z when you hear the clicking? stopping, starting, or when you shift?
I haven't heard any clicking in mine (yet). I am happy for that.
Old Apr 17, 2008 | 12:42 PM
Blaumph's Avatar
Blaumph
I get the same noise, and have noticed that when I hit the rear defrost button, the noise stops for a second then slowly comes back.
Old Apr 17, 2008 | 02:27 PM
j0hns0nc's Avatar
j0hns0nc
i only hear a high pitch noise when im going like 80mph. i always just assume that my window wasnt closed fully
Old Apr 17, 2008 | 04:38 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
You guys are killing me!
If you hear it with the radio off its the Fuel pump.
If you hear it with the radio on, it your cheap stereo install.
If you hear it when you build speed its your rear end (mostly after market LSD)
My car sounds like a 747 with my dual fuel pumps.
Old Apr 17, 2008 | 06:05 PM
Blaumph's Avatar
Blaumph
If the OP's noise is like mine, which it sounds like it is, it's not the radio, and it's most likely not the fuel pump. It's definitely an electrical issue. If it were the fuel pump, why would the noise stop when the rear defrost button is pressed, and then why would it fade back in after a couple seconds? Also, since the noise is coming from the mid/rear of the cabin, how could it be the fuel pump?
Fuel pump, tranny, diff noise is not what I'm hearing.
Old Apr 18, 2008 | 03:24 AM
fatinma's Avatar
fatinma
Thanks. You've been a pant-load of help.
