dealership problem with ebrake not holding
Old May 9, 2008 | 12:19 AM
slanteyez's Avatar
slanteyez
Default dealership problem with ebrake not holding
my ebrake takes like 20 clicks until it actually feels like its holding, but on a hill it barely holds still rolls backwards slowly. i took it to the dealership since im still under warranty and they told me that i have to replace my rear brakepads to fix the problem! so that means its not covered by warranty since its a "wear and tear" item! wtf i thought the handbrake just needs adjusting?
Old May 9, 2008 | 11:39 AM
SuperGood's Avatar
SuperGood
I have a 03 Track model with the same problem. I just ordered new brake pads and will install them when they arrive. They need to be replaced anyway as the pads are super thin. Hopefully that will fix the problem.
Old May 10, 2008 | 09:40 AM
Z Hotness's Avatar
Z Hotness
I had the same problem and took it in they said nothing was wrong but I noticed they tightened the hand brake. I know my rear brake pads are fine so that isn't my problem. I asked about hand brake tightening and they quoted me over $100... They said its not under warranty since it is technically "wear and tear".
Old May 10, 2008 | 01:28 PM
halcyon901's Avatar
halcyon901
Slanteyez, i got the same problem. I guess the person that had the car before me was f**king around, trying to drift using the e-brake! I cant even really park on hills, i have to pull the handle all the way up for it to really engage! now, after reading your post, seems like i gotta pay to get it fixed!
Old May 17, 2008 | 11:17 AM
padam07's Avatar
padam07
There are two sets of brake pads on the rear. One set actually brakes the car and then there is a drum style set for the ebrake. They can go out of adjustment or they could be worn out from too much abuse.
Old May 17, 2008 | 01:17 PM
If you take the car to the dealers because the windows do not work, they will still sell you brake pads.
Uriyo_
Sep 8, 2021 08:46 AM
