HELP!!!! Clutch stuck to the floor!
Old May 9, 2008 | 03:06 AM
john1982's Avatar
john1982
Default HELP!!!! Clutch stuck to the floor!
I was in first gear and went to push the clutch in to get it out of first, pressed it in and about half way down there was no pressure and it fell to the floor and stayed there....the car stalled cuz it was in first. iwent down to the footwell and pulled the clutch back up....about a 1/4 of the way up, it will snap back to the top....but if i start to press it in, it will snap to the floor...can't figure out what the problem is...can anyone please help? thanks
Old May 9, 2008 | 10:12 AM
john1982's Avatar
john1982
anyone?
Old May 9, 2008 | 10:15 AM
SpoilsofWar's Avatar
SpoilsofWar
You have no (or low) clutch fluid, or air in the clutch line.
Old May 9, 2008 | 10:27 AM
LAKERSFAN's Avatar
LAKERSFAN
Sounds like you need the master cylinder and/or slave cylinder replaced. Should be under warranty. Take it to the stealership.
just went through the same thing myself. Also, i upgraded the clutch line and fluid. figured couldnt hurt since labor was under warranty as well.
spent a little less than $100.00 for the nismo steel clutch line and motul fluid. Helps to keep the fluid from boiling, i guess.
Old May 9, 2008 | 02:32 PM
350Z400rwhp's Avatar
350Z400rwhp
Slave unit bad, air in line or bad pivot ball.
Old May 14, 2008 | 03:27 AM
john1982's Avatar
john1982
hey thanks for all the answers guys.....now i just have to find the time to get it done, prob. this weekend...i'm gonna start by trying to bleed the clutch then if that dosent work then i'll change the master and slave cylinder, if that dosen't work then i know i'm in trouble....hopefully it just needs bleeding!
07rdsterGT's Avatar
07rdsterGT
Agreed.
Old May 14, 2008 | 03:45 AM
john1982's Avatar
john1982
just called dealership and asked if it was covered under powertrain warranty, they said no. then i asked what exactly is covered under the powertrain warranty and they couldn't give me a straight answer....so another question for you guys is: If it is the master cylinder and slave cylinder, will it be covered under the powertrain warranty?
Old May 14, 2008 | 04:18 AM
07rdsterGT's Avatar
07rdsterGT
No.
For a Nissan, the basic warranty gives coverage for 3 years or 36,000 miles, whichever comes first. The powertrain warranty lasts 5 years or 60,000 miles. A powertrain warranty covers the major mechanical components while a basic warranty covers almost everything (except wear and tear parts). Once these warranties both expire, the vehicle owner is likely to need an extended warranty to prevent high automotive repair bills. In many cases, a vehicle owner discovers quickly that one repair could cost more than the cost of the extended warranty. This is the reason that extended warranties are popular among vehicle owners today.
This is why I paid the extra 1,300 and got the full 7 year bumper to bumper.
Old May 14, 2008 | 04:19 AM
phreaktor's Avatar
phreaktor
Design Engineer
pivot ball
Old May 14, 2008 | 06:36 AM
john1982's Avatar
john1982
ok....well that sux! should have gotten the extended warranty!......i heard a few people talk about the pivot ball....does the tranny have to be dropped to fix this?
Old May 14, 2008 | 06:55 AM
cheshirecat79's Avatar
cheshirecat79
If the dealership is denying you based on the clutch being a wear and tear item, a full warranty would not cover this either.
If a portion of the clutch is bad/defective and leaking fluid, I would push to get that covered under powertrain, and stress that it's not wear and tear, it's a part defect from the factory.
However, since your car is an '03, I would chalk this up to old/boiling clutch fluid and/or clutch line issues. Check to see if you have fluid leakage. If you don't, flush it out with some better fluid and see about upgrading your clutch line.
Old Feb 20, 2013 | 03:59 PM
jeggo's Avatar
jeggo
I'll just bump this up. Just had the same problem. The reservoir was empty when I checked ot now. When I filled if up, there was something leaking at the middle part at the bottom of the car. Now, it stopped but the reservoir is not moving. I should say I live in Edmonton and its -10 now here if that matters.
Any inputs? I plan of just having it towed to my apartment and check it tomorrow morning as the sun is almost gone now. Any inputs will be appreciated.
What can I do? Should I just go to the dealership? I just want to know you guys opinion
Old Feb 21, 2013 | 07:15 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Assuming you have a 07-08? Sounds like your Clutch Slave popped.
You need this
http://www.zspeedperformance.com/ZSp...ZSPHDSLAVE.htm
Old Feb 21, 2013 | 12:39 PM
travlee's Avatar
travlee
Master
Spend the money on the zspeed kit or you will replace it again. Mine crapped out on me 6 weeks after buying the car...replaced with stock and 20k miles later it did it again. The master that zspeed sends with the kit is willwood with all stainless braided lines
Old Aug 10, 2013 | 07:07 AM
Lynx350Z's Avatar
Lynx350Z
I had the same issue in my 07 Z. I upgraded my clutch but didn't do master and slave, shortly after I had the same exact thing happen to me that happened to you. I bought the slave and master cylinder kit from ZSpeed, installed it and haven't had a issue since.
Old Jun 21, 2014 | 10:44 AM
apeman1213's Avatar
apeman1213
Yup, this is what is exactly what I woke up to. Clutch on the floor.
google says it's a common problem for the year?
Old Jun 21, 2014 | 12:37 PM
oldschool350z's Avatar
oldschool350z
Slave and it's a ***** I think the transmission actually needs to be pulled to this fix..
Old Jun 23, 2014 | 08:20 AM
JohnnyC128's Avatar
JohnnyC128
I had that happen while I was about 50 miles away at the coast. I had to drive it back with no clutch and it's not bad. I only had to do a start from stop a couple of times and the starter had no problem starting the car in first gear with no clutch. After that, just find the sweet spot during shifts and your off and running. Mine WAS the ball pivot and yes, you do have to pull the trans to change it. I did the clutch plate as long as I was in there and it's been awesome ever since!
Old Aug 14, 2014 | 07:13 AM
apeman1213's Avatar
apeman1213
Yes sir, I switched out the clutch since I was already dropping the transmission.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
