Help me engine was smoking...
Originally Posted by leemik
it might just be some coolant that was spilled during install and just needs to burned off.. run the car with the hood up and the smoke doesn't stop after a few minutes then you probably have a leak
look for dripping or a puddle under your car.. you won't be doing harm to the car unless you are overheating.
Its fixed!
If the smoke is being produced from the spilt coolant the smoke will have a very sweet rich smell to it. it wont smell like smoke your probably used to. From the sounds of it the coolant was pissing on the side of your block and steaming/smoking out underneath the car.
NOT OK.. something is still wrong....
I took it for a test drive for about 3-5 mins and it started getting a little hotter than it should so I shut it down and gave it a 30 minute break while I checked the engine. All of a sudden there was barely any coolant in the bottle it was under minimum. I walked to the store and bought some to fill it up and filled it to max.
I waited till the engine was cooled down and drove it home. As I got home again there is no coolant in there. WTF is going on...
Originally Posted by CSF
just a shot in the dark. did you install a coolant bypass valve with your motordyne spacer? if you did, make sure there's no leaks around there.
Everytime I refill the coolant I check the ground and there is nothing on the ground.. where is it going.
Originally Posted by phreaktor
You put oil on the gasket? What is it made out of?
Are you still getting "smoke" out of your exhaust?
If yes, put your hand in front of your tailpipe and see if it is really steam. Steam will condense into water on your hand.
you probably sucked air into the system with that hose. Bleed system, refill, bleed system, refill, bleed system refill. Good luck partner getting air out can be a pain in the ***.
Originally Posted by Asian Invasian
ugh I had to bleed that sucker like 5-6 times... My heater works and I drove for about 5 mins no overheating.. I think I am good now. What a PITA day.
liqalu04
Jan 2, 2022 12:58 PM
