Engine Overheat Light + Leak = ???
Old Jun 9, 2008 | 01:17 PM
Sandok's Avatar
Sandok
Default Engine Overheat Light + Leak = ???
I just got the engine overheat sign after driving the Z quite hard and immediately did whatever the Nissan manual suggest, to no avail.
I did the ECU reset, no go... The oil temp light is still on, even though I haven't driven the car for 12 hours in the Z!!!
So I decided to check for leaks and well, found a damp puddle under the car (maybe two puddles, not sure) I attached some pics of where the leak is comming from (the one I could find).
Any ideas? This is coming at the same time as my exams and definately sucks... I need info guys!
BTW, I don't see how the two can be linked... (exhaust and system temp?)
Attached Thumbnails Engine Overheat Light + Leak = ???-leak_1.jpg   Engine Overheat Light + Leak = ???-leak_2.jpg   Engine Overheat Light + Leak = ???-leak_3.jpg
Old Jun 10, 2008 | 06:48 AM
Thermal1's Avatar
Thermal1
Errr is that oil coming out your exhaust? Thats bad
Check your oil level on the dipstick. You might have run out of oil.
Old Jun 13, 2008 | 10:18 AM
Sandok's Avatar
Sandok
I touched it with my fingers, the liquid is clear... Seems like water (no smell no nothing) but I'll check my oil levels tomorrow ASAP.
Old Jun 29, 2008 | 03:04 PM
_350Lee_'s Avatar
_350Lee_
double check your coolant levels. the only way for water to get in the exhaust is through the head gaskets. not good.
Old Jun 30, 2008 | 07:53 AM
j.arnaldo's Avatar
j.arnaldo
NOT good, if it's gaskets!
Old Jun 30, 2008 | 08:11 AM
SpoilsofWar's Avatar
SpoilsofWar
Taste the water... If its sweet (or bitter) its coolant. If the taste is neutral, it could be water from your A/C system (assuming you were using it).
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
samansharif
Sep 25, 2015 12:31 PM
