changed clutch now car wont start help!!!
Old Jul 6, 2008 | 11:14 PM
drftrz's Avatar
drftrz
Default changed clutch now car wont start help!!!
i have an 05 350z and i changed my clutch recently and now the clutch pedal wont come up it just sticks to the floor and its actually pulled to the fllor with pressure. to get the the clutch to come back up you have to force it up and then it pops up and when you try to turn on the car the engine turns but the car wont start please help!!!!
already tried bleeding the line
Old Jul 6, 2008 | 11:23 PM
SuperBlack350z's Avatar
SuperBlack350z
bleed the clutch .
Old Jul 6, 2008 | 11:25 PM
drftrz's Avatar
drftrz
already did it still no dice
Old Jul 7, 2008 | 12:02 AM
Spork's Avatar
Spork
Did you install the throwout bearing, etc correctly?
Old Jul 7, 2008 | 12:48 AM
drftrz's Avatar
drftrz
ya im positive the throwout bearing was installed correctly because we had to press it on to the transmission
is there an adjustement on the cluth itself that would do that fix it?
Old Jul 7, 2008 | 05:01 AM
captj3's Avatar
captj3
You probably damaged the slave cylinder. As for it not starting you also most likely damaged the crank postion sensor. Just replace it for $55 from the dealer. That part is more delicate than people think.
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
