the car does not respond to trottle
Old Jul 8, 2008 | 09:57 AM
HP 350Z's Avatar
HP 350Z
Default the car does not respond to trottle
my car starts but it die when i give it gas . the car started acting up last winter when it saw snow for its 1st time . the car would run and all of but all of a sudden the gas peddal would stop responding . i would then turn off the car and turn it back on so it would go away. but now the car stop responding and when it turns and give it gas it dies.
i have replaced the throttle body . the only thing i have not check is the maf sensor
anyone has any ideas ??
Old Jul 8, 2008 | 09:59 AM
03BrickyardZ's Avatar
03BrickyardZ
Issue with TCS, maybe? Thats all I can think of if it happens in turns.
Old Jul 8, 2008 | 10:00 AM
JAM3Z's Avatar
JAM3Z
Phenom
I think its either your throttle body going or your throttle position sensor.
Old Jul 8, 2008 | 01:21 PM
Socalbred's Avatar
Socalbred
Are all the bolts on the intake manifold tight? You may have a slight vacuum leak.
Old Jul 8, 2008 | 02:18 PM
DavesZ#3's Avatar
DavesZ#3
After replacing the throttle body, did you do the three recalibration procedures....
https://my350z.com/forum/maintenance-and-repair/371324-how-do-i-do-the-throttle-body-relearn-procedure.html
Old Jul 8, 2008 | 05:38 PM
HP 350Z's Avatar
HP 350Z
i just replaced the throttle body. and position sensor
Old Jul 8, 2008 | 05:44 PM
HP 350Z's Avatar
HP 350Z
https://my350z.com/forum/showthread.php?t=371324
thanks for the info i will try that tomorow
Old Jul 8, 2008 | 05:49 PM
HP 350Z's Avatar
HP 350Z
yeap everything is tight. the only codes i keep on getting is the throttle position code and when it goes away i would get the mass air sensor code. they have been taking turns on and off for the past couple of months .
Old Jul 8, 2008 | 05:50 PM
HP 350Z's Avatar
HP 350Z
well the VDC says off . ever since i went with bigger rims i cannot turn that on so i doubt is that
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
