help! code is P1121
Old Jul 16, 2008 | 07:55 AM
smokedout350z's Avatar
smokedout350z
Default help! code is P1121
just pulled up the code at advance auto's...code P1121 (air metering)...
what do i need to do?
Old Jul 16, 2008 | 07:57 AM
smokedout350z
ok found it ..but what the heck do i need to do to this..i don't know what it is..P1121 Electronic Throttle Control Actuator
Old Jul 16, 2008 | 08:21 AM
HondaKiller's Avatar
HondaKiller
Run the TB reset procedure
Old Jul 27, 2008 | 05:25 PM
chromesilverz's Avatar
chromesilverz
Old Jul 27, 2008 | 05:26 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
sounds like a throttle body problem.
Old Jul 27, 2008 | 05:34 PM
surfcity40's Avatar
surfcity40
in every car 1121 is throttle control is LOWER than expected. If it was the TB you'd have another code.
It's a bad sensor imo. they're relatively inexpensiveand a lot of folk here deal with this issue.
Old Jul 28, 2008 | 11:20 AM
sixsigmalarry's Avatar
sixsigmalarry
Wink
+1.....try it and see what happens! Can't hurt and it's free!
Old Feb 18, 2024 | 06:17 AM
K1000 350z's Avatar
K1000 350z
Default What does it mean TB? I m spanish , thank you
Old Feb 18, 2024 | 09:40 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Throttle Body
However, the discussion of DTC P1121 is incorrect. It is NOT a throttle body fault; rather a faulty APS or Accelerator Position Switch and also called electronic throttle control sensor (or something like that). This is the small unit above your accelerator pedal that converts where your throttle is (physically) and sends the signal to the throttle 's DBW (drive-by-wire) system.
Relatively easy to test (just need a MultimeterVOM) and replace.Also not terribly expensive.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
