what are the bolts and how to unscrew them (front suspension)
Old Jul 31, 2008 | 11:49 AM
hijack's Avatar
hijack
Default what are the bolts and how to unscrew them (front suspension)
hi all
this is the picture of a front suspension of 350z
in the right up corner there is part named sec 750 (54422P)
actually as I understand it's about BOLTS that are fixing this big part (sorry, don't know how to call it)/ there are 2 bolts from every end.
so the problem is that my mechanic can't unscrew it, 13 is too small, 14 is too big
does anybody know that part? what tool should be used?
thanks
Attached Thumbnails what are the bolts and how to unscrew them (front suspension)-image.asp.jpg
Old Jul 31, 2008 | 11:58 AM
350ZTheStandard's Avatar
350ZTheStandard
I can't read Russian, this is from your link:
У нашего провайдера существует разограничение на российский/зарубежный трафик.
К сожалению для IP 75.173.141.181 доступ закрыт.
"Российским" считается трафик от любого объекта сети, IP-адрес которого попадает в список "российских" IP-сетей провайдера.
Список IP-адресов стран СНГ обновляется из публикуемых списков IP-адресов соответствующих стран.
Проверить принадлежность вашего IP вы можете по базе WHOIS RIPE NCC
Old Jul 31, 2008 | 01:02 PM
Motormouth's Avatar
Motormouth
I think my IP is blocked. please host a picture that we can view on THIS website and mark on the picture the bolt you are referencing.
Old Aug 1, 2008 | 02:46 AM
hijack's Avatar
hijack
I'm sorry...
updated picture
Old Aug 1, 2008 | 06:21 AM
Tim@WestCovinaNissan's Avatar
If it's the upper control arm bolts you are talking about a 14 should fit and work fine. Just have them retorqued that usually fixes the problem.
Obadabot
Jun 18, 2023 11:31 PM
