Gas Door / Fuel Door fix
Old Aug 6, 2008 | 04:57 AM
RN7676's Avatar
RN7676
Default Gas Door / Fuel Door fix
I noticed some people posting about their gas door not being flush. ... So here goes.
It is adjustable. Pop it open and you'll see it is held on by two phillips screws. The bracket those screws go through has elongated holes, so it can be centered. Adjusting its depth takes a tiny bit of ingenuity. The shop manual doesn't cover ingenuity which is why your Nissan dealer can't fix it.
Your adjustments may be different. ... In my case, I put two washers underneath the lower bracket hole (between the bracket and the gas door assembly). The washers made it level, then I loosened and tightened those screws and adjusted it until I got it perfect.
So by putting washers under the top screw or bottom screw (or both) you can rock the whole panel in and out.
Use thin washers, that way you can stack them and have more adjustment. I used two plastic nylon washers because that is what was at the top of my washer pile. I probably should have painted them black.
The stock screws are barely long enough. If you put any washers / spacers in there the screws will have no chance of reaching the threads. You'll need a metric screw M5 x 0.8 at 3/4" maximum length.
Anyways, I think it took about 5 minutes and I didn't even get dirty!
Attached Thumbnails Gas Door / Fuel Door fix-crooked.jpg   Gas Door / Fuel Door fix-washers.jpg   Gas Door / Fuel Door fix-done.jpg
Old Aug 6, 2008 | 05:00 AM
bmaiZ's Avatar
bmaiZ
good info. thanks for sharing.
Old Aug 6, 2008 | 05:04 AM
huyrua's Avatar
huyrua
ingenuity FTW
Old Aug 6, 2008 | 05:49 AM
nothix's Avatar
nothix
damn I think I need to do this.
Good Write up, should be moved to the DIY section
Thanks OP
Old Aug 6, 2008 | 06:08 AM
KManZ's Avatar
KManZ
Nice one!
This fix will come in handy, thanks for contributing.
Old Aug 6, 2008 | 06:14 AM
sbZenth's Avatar
sbZenth
oooh i needed to do this. thanks
Old Aug 6, 2008 | 06:24 AM
Louis21's Avatar
Louis21
Thanks! I needed that!!!!
Old Aug 6, 2008 | 06:38 AM
Z_HighSpeed's Avatar
Z_HighSpeed
im gana try this.
Old Aug 6, 2008 | 06:50 AM
PerfZ's Avatar
PerfZ
Great solution. And once it is aligned properly, the hatch will open on the 1st touch of the button, which was a major PITA on at least the '03 models.
Old Aug 6, 2008 | 07:34 AM
raulzito's Avatar
raulzito
Hey, good post!
Old Aug 6, 2008 | 08:47 AM
Done Deal DR's Avatar
Done Deal DR
My '04 has the same problem. I usually have to push it a couple of times. One time, after stopping at the gas station to fill up maybe a few months after I had purchased my Z, I pushed it a few times and it didn't open. I pushed that SOB HARD! Next thing I know I had pushed the button in so hard that the button itself was inside my dash!
I of course had that, "oh ****!" look, but luckily the button just pops back in. So playing around with the alignment should make it open right away? This has always pissed me off a bit, but looking at my gas cap, it really doesn't seem to have any alignment issues. It seems dead center and seems to be on a level plane with the rest of the vehicle body.
Old Aug 6, 2008 | 09:09 AM
BaTMan_4's Avatar
BaTMan_4
will be doing this later this week
Old Aug 7, 2008 | 06:19 AM
rotchcrocket04's Avatar
rotchcrocket04
x2
Thanks OP
Old Aug 7, 2008 | 06:52 AM
engiNERD350Z's Avatar
engiNERD350Z
Thanks!!! Doing it tonight!
Old Aug 7, 2008 | 03:17 PM
Peteski's Avatar
Peteski
Nice write up, dont need to do this myself but thanks for sharing!
Old Aug 7, 2008 | 03:21 PM
mw9's Avatar
mw9
+1, I always hated that damn fuel door.
Old Aug 7, 2008 | 04:52 PM
MCDesign's Avatar
MCDesign
Wow! Nissan=FAIL my car has had a saggy fuel door since day 1. This literally only took me 37 seconds to do and the passenger side of my car looks 10 times better. Great write-up man I have been waiting for someone to find a cure for my ole' saggy fuel door lol.
Old Aug 8, 2008 | 07:47 AM
Spoiled Z's Avatar
Spoiled Z
Im going to do his once I get my car back from the shop. Thanks!
Old Dec 1, 2008 | 11:57 AM
JMC813's Avatar
JMC813
Just did this. Excellen write up! Works good, not perfect, but better than before. Thanks!!
Old Dec 1, 2008 | 02:11 PM
kelsey_kaye's Avatar
kelsey_kaye
i've always wanted to adjust mine cause it sits up on the bottom, but i've always just been too lazy.
