Crank sensor circuit error, Help!
Old Aug 16, 2008 | 02:36 PM
NOSDEVIL's Avatar
NOSDEVIL
Default Crank sensor circuit error, Help!
My turbonetics 350z was getting tuned kast week and the check ingine light came on as well as the cars RPM's were bouncing once I hit 5,500 while at full throtle and the graph was all over the place. Needless to say we could not tune the car due to this problem. It also has a Utech installed on it. I took out the crank sensor today and cleaned it off and I cleared the error code but the same thing happened again once I took it for a test drive. Has this happened to any of you? Does anyone know what would cause this to happen?
Old Aug 18, 2008 | 04:59 AM
Dr. Venture's Avatar
Dr. Venture
whats the code?
Old Aug 18, 2008 | 05:19 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
just replace the sensor they do go bad
Old Aug 20, 2008 | 05:36 PM
NOSDEVIL's Avatar
NOSDEVIL
Im not sure what the code is but I will replace it and see if that takes care of the problem.
Old Sep 15, 2008 | 10:42 AM
ADMAN's Avatar
ADMAN
Did it fix the problem???
liqalu04
Jan 2, 2022 12:58 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
