Cruise control does not work!?
Old Aug 21, 2008 | 04:48 PM
350zna's Avatar
350zna
Default Cruise control does not work!?
Hey guys, just the other day i am coming up to school here at penn state and i decide to throw on the Cruise control and it just did not want to work. The light turns on but it will not hold on a speed it just does not work. I had a new alpine HU installed last month by Tweeters in king of prussia and i was wondering if replacing the HU would have anything to do with the CC to stop working. Any help is greatly appreciated, and it is hard to take my car to the dealer in between rugby and class. Thanks guys.
Old Aug 22, 2008 | 07:11 AM
350zna's Avatar
350zna
any ideas guys? would the new HU be the problem?
Old Aug 22, 2008 | 09:21 AM
DavesZ#3's Avatar
DavesZ#3
It's always possible that something got disconnected when they were working on your install, but most of the time, when that happens, the car throws a CEL/SES light to indicate a problem.
There are a dozen things that can affect Cruise, from wiring, switches, etc. all the way to the vehicle speed sensor. The dealer will probably have to hood it up to the computer to know for sure.
Probably the only easy thing you can check is the clutch and brake switches. If those are broke or not adjusted properly, the car might think you have the clutch or brake depressed and that would normally kick you our of cruise. Same thing with transmission switches, if it thinks it's in neutral, then cruise disengages.
Old Aug 22, 2008 | 10:19 AM
350zna's Avatar
350zna
thank you
Old Mar 17, 2010 | 12:32 PM
lethal3's Avatar
lethal3
Old topic, i know but i have the same issue. non working cruize, and an alpine HU. I also have a cel because of test pipes.
has there been a solution for this, i have non foulers but i still get cel
Old Mar 23, 2010 | 07:35 AM
lethal3's Avatar
lethal3
Does anyone have info on this?
Old Mar 23, 2010 | 07:48 AM
TJGILROY's Avatar
TJGILROY
there's cruise control on the Z!!!!!???? hahaha... jk
Old Mar 23, 2010 | 08:54 AM
DavesZ#3's Avatar
DavesZ#3
^^^ Only on the real Zs.
Old Mar 23, 2010 | 08:56 AM
MrWatchDawg's Avatar
MrWatchDawg
well also i heard that if you install some after market tail lights it breaks the cruiser control. So i have been told and read
Old Mar 23, 2010 | 10:13 AM
TJGILROY's Avatar
TJGILROY
???....i was joking...only the base doesn't have them, right?
Old Mar 23, 2010 | 01:56 PM
DavesZ#3's Avatar
DavesZ#3
Correct, no cruise in the base. I was joking too... base != "real" Z. No cruise, no hid, no LSD...
_bit
Oct 2, 2015 07:49 AM
