Having problems with my 2007 CS
Old Mar 22, 2010 | 05:49 PM
SDbackstock's Avatar
SDbackstock
Default Having problems with my 2007 CS
So I haven't been having any problems lately, but yesterday when I took the Z, my radio and dashboard will randomly shut on/off (flicker) occasionally. I only have 48k miles, and I think it is a bit soon for my alternator to start failing on me.. Anyone else encounter this problem on their Z? Could It possibly just be a bad drive belt?? Any help is appreciated. Thanks.
Old Mar 22, 2010 | 06:05 PM
350ZTheStandard's Avatar
350ZTheStandard
Are you the original owner of the car or did you buy somebody's problem??
Old Mar 22, 2010 | 06:08 PM
SDbackstock
I bought it off someone else, but I've had the car for about a year now.. and it is just now having this symptom.
Old Mar 22, 2010 | 06:39 PM
350ZTheStandard
Maybe you have some loose electrical connections, or possibly the alternator is going out. Either way you can get you alternator tested for free, this of course needs to be out of the car, usually. Good luck & find a shop that you can trust.
Old Mar 22, 2010 | 08:45 PM
johnwigs's Avatar
johnwigs
how does a "dashboard" flicker on and off?
Old Mar 22, 2010 | 08:59 PM
a. Lose connection.
b. Power line intermittently touching a ground.
c. Faulty fuse. Improperly installed fuse.
Old Mar 22, 2010 | 10:23 PM
SDbackstock
Yeah.. That's what I was thinking. Thanks for the advice.
It is more than assumable what I am referring to..
a. Lose connection.
B and C I think should be good, but I'll have to check out A, thanks for the suggestion.
Old Mar 23, 2010 | 07:48 PM
johnwigs's Avatar
johnwigs
im saying that I have never seen your symptom described as dashboard flickering... and an altenator going out you would have the battery light on your cluster on... I work at mossy and I have never seen an elctrical problem that wasnt caused by someone else... or bad grounds... grounds are the worst on nissans!!!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
