Had sway bars installed and now Slip light will not go off?
Old Aug 24, 2008 | 04:58 PM
Slow*Jim's Avatar
Slow*Jim
Default Had sway bars installed and now Slip light will not go off?
Hey guys. I had Hotchkis Sways installed with PowerGrid endlinks last week and when I got the car back, the VDC, Slip, and Ebrake lights will not go off. I assume this is a wheel speed sensor that they knocked out of whack or something?
Is this an easy fix I can do in my garage? Any DIY's out there?
Old Aug 24, 2008 | 05:07 PM
DavesZ#3's Avatar
DavesZ#3
I can't say I've seen a DIY on speed sensors.
I'd check the easy stuff first - make sure the connectors are not damaged or loose.
Old Aug 25, 2008 | 12:26 AM
terrasmak's Avatar
Check you brake fluid first , it may have gotten to the low point at just the right time. Second, the connection to the speed sensors, there is really no way to damage the sensor during the install , but every possible to unplug or yank a wire.
Old Aug 25, 2008 | 07:09 PM
Slow*Jim's Avatar
Slow*Jim
Thanks for the help guys.
Doing all 4 rotors and pads tomorrow so I will check fluid.
Old Aug 31, 2008 | 07:25 PM
stealthz's Avatar
stealthz
if your brakes are low those lights will come on as well
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
