2nd to 3rd gear grinding
Old Aug 27, 2008 | 02:24 PM
will4992's Avatar
will4992
Default 2nd to 3rd gear grinding
when shifting from 2nd to 3rd gear, if i do not change the gear in a certain way( i have to hold the clutch in for about a second then move the shifter straight into third) it will slightly grind the gear. Has anyone had this problem? any ideas on how to fix it? It has been happening almost as long as i can remember.
Old Aug 27, 2008 | 02:26 PM
bboypuertoroc's Avatar
bboypuertoroc
When was the last time you changed tranny fluid?
Old Aug 27, 2008 | 04:55 PM
Chaser720's Avatar
Chaser720
Lemoned Z
That called a syncro going bad. Basically your tranny is shot and needs to be replaced or rebuilt.
Im on my third at 30K and its grinding too (but 6th).
Old Aug 27, 2008 | 05:24 PM
will4992's Avatar
will4992
how much do you think it would cost to get rebuilt or how much would a new one cost?
Old Aug 31, 2008 | 07:14 PM
stealthz's Avatar
stealthz
how old is your z and how many miles? do you still have a factory warranty or extended warranty... ?
Old Sep 1, 2008 | 11:01 AM
TTwinTTurbo's Avatar
TTwinTTurbo
I had mine replaced for 3500 dollars I think the bill came to be. It was under warrantee though
Old Sep 1, 2008 | 11:03 AM
TTwinTTurbo
What? You've had 3 trannies? You must be rallying it or something.. What happened with the two that failed? A synchro went out?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
pslamp32
Feb 8, 2017 09:07 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
