Interesting issue..
Old Sep 10, 2008 | 02:12 PM
Paintballislife's Avatar
Paintballislife
Default Interesting issue..
Approximatley one week ago i totally stripped down the plenum assembly cleaned everything, throttle body upper lower, ports to valves everything. Re-assembled, Installed 5/16th spacer, no issues after initial start up besides rpm hovering around 1050-1100. Reset the ecu for the throttle body idle air everything. code goes away rpm settles to around 750. Turn off car, restart back to square one. Went to Dr. Venture's lab and still even after hooked up to a diag and following its Throttle body reset, no joy. Only thing that works is Idle air relearn. There is no rough idle it stays steady, but i cant hold it at a certain RPM, like 2K or 3k, and sometimes there is a lag when releasing the pedal. I have no idea what this could be..
Any Ideas?
Old Sep 13, 2008 | 10:53 AM
Paintballislife
anyone have any advice?
Old Sep 18, 2008 | 03:40 PM
Paintballislife
hellloooo
Old Sep 22, 2008 | 01:40 PM
VO...'s Avatar
VO...
Administrator
Have you double checked to make sure all hoses and sensors were repluged in after installation?
Alexreyes
Sep 30, 2015 11:30 PM
