Car problem need help.
Old Aug 30, 2008 | 09:19 AM
ZDUB's Avatar
ZDUB
Default Car problem need help.
I have an 03 350z. Every time I turn the ignition on, the car starts fine but it idles way down and sometimes it shuts off. It does not happen at all times but recently it's been happening more often. Any advice on what could be the problem. My car is stock.
Old Aug 30, 2008 | 09:42 AM
Machupo's Avatar
Machupo
if the idle hunts (moves around, sounds like you've got huge cams), then you might have a vacuum leak on the intake / plenum.
Old Aug 31, 2008 | 12:45 PM
ZDUB's Avatar
ZDUB
You think that's the problem? Thanks.
Old Aug 31, 2008 | 11:34 PM
Machupo's Avatar
Machupo
might be, at least it's an inexpensive first step to check
open the hood and then have someone start the car (or start it and run around) and listen for high whistling sounds coming from anywhere along the intake / plenum area. That'll be a dead giveaway.
Old Sep 17, 2008 | 11:00 PM
ZDUB's Avatar
ZDUB
Problem fixed.
Old Sep 18, 2008 | 08:52 AM
ADMAN's Avatar
ADMAN
Originally Posted by ZDUB
Problem fixed.
What was it - vaccuum leak???
Old Sep 18, 2008 | 08:55 AM
VO...'s Avatar
VO...
Administrator
+1
Tell us what the fix was or this thread is useless to other...
Old Sep 19, 2008 | 09:22 AM
ZDUB's Avatar
ZDUB
It was a vaccuum leak.
Old Sep 19, 2008 | 06:13 PM
VO...'s Avatar
VO...
Administrator
Where? Details man! Pics. Something...
Old Sep 22, 2008 | 06:56 AM
VO...'s Avatar
VO...
Administrator
I sent the OP a PM. I want to know where the problem was...
Old Sep 22, 2008 | 04:20 PM
ZDUB's Avatar
ZDUB
Took the car to my dad's mechanic told him about the problem and told him it might be a vaccuum leak, left the car there he fixed it within 2hrs. When I came back the car was good, he said was a vaccuum leak. Problem solve.
Old Sep 22, 2008 | 07:46 PM
VO...'s Avatar
VO...
Administrator
Gotcha. Glad you got it fixed. I was hoping we could've known what the exact problem source was. It could've helped someone out in the future. Maybe next time. Thanks for responding...
Chris350z03
Oct 8, 2023 07:19 PM
SonnyWu
Nov 24, 2015 08:19 PM
Ronso
Oct 30, 2015 12:39 PM
h8redlights
Sep 11, 2015 07:57 PM
PureR3d
Sep 10, 2015 06:23 PM
