tach bouncing at low rpms and car lagging! help!
Old Sep 17, 2008 | 07:28 PM
runnun's Avatar
runnun
Exclamation tach bouncing at low rpms and car lagging! help!
This all happened when I was pulled over on the side of the road because I missed and exit. when I went to take off again my VDC was off and I was on those bumps on the side of the road (the ones so you dont drift off to sleep) I did a rather harsh takeoff because there was alot of traffic. after that I noticed my tach fluttering at low rpm's and the car lagging with it not accelerating properly. I inspected the car thinking it might be the exhaust but couldnt find anything. the problem seems to come and go. I hit some more bumps after that and it started doing it again. I'm thinking its the transmission or driveshaft? really dont know. I'll put it on a lift soon. It just happened tonight.
please help!
Old Sep 18, 2008 | 07:46 AM
runnun's Avatar
runnun
anyone?
Old Sep 18, 2008 | 08:54 AM
ADMAN's Avatar
ADMAN
Only happening when your car is bouncing? Or, still happening now??
Old Sep 18, 2008 | 10:03 AM
runnun's Avatar
runnun
still happening now. I looked for leaks under the car and didnt see anything.
its mostly at low rpms mostly in 2nd gear 1,000-4500 rpms
Old Sep 18, 2008 | 10:30 AM
Spork's Avatar
Spork
Try resetting the ecu by unplugging the negative battery terminal for 20 minutes.
Also, to be safe, you can clean your MAF with electronics cleaner.
Old Sep 18, 2008 | 12:08 PM
ADMAN's Avatar
ADMAN
+1 on MAF. And, possibly resetting your Idle Air.
Old Sep 18, 2008 | 02:22 PM
runnun's Avatar
runnun
thanks will try
Old Sep 19, 2008 | 09:42 AM
runnun's Avatar
runnun
ok so I reset the ecu and cleaned the maf.I have a new symtom today the car makes loud knocking noises over bumps or turns -happens alot almost as if something is popping...acceleration problem is still happening..
I schedualed apt at the dealer for next thurs
Old Sep 19, 2008 | 09:43 AM
runnun's Avatar
runnun
oh the popping/knocking is coming from right under my feet d/s from the front end of the car I can feel it in the pedal too
Old Sep 19, 2008 | 01:55 PM
ADMAN's Avatar
ADMAN
Sway bar? Strut? Keep us posted...
Old Sep 19, 2008 | 04:45 PM
mw9's Avatar
mw9
how do you reset your idle air
Old Sep 23, 2008 | 07:19 PM
runnun's Avatar
runnun
ok so I got a service engine soon light so- I checked the codes and got P0230 or catalist efficency below threshhold bank 2...could this be the problem with my accleration? I cleared the code so I'm going to drive it tommorow and see if it will come back on in a drive cycle.
please help!
Old Sep 25, 2008 | 10:54 AM
runnun's Avatar
runnun
so nissan wont work on my car because I have too many after market parts! wtf! I have to take it somewhere else! their blaming my aftermarket sway bars for noise when thats clearly not it. ***** idiots!
etkms
Jun 19, 2022 06:30 PM
05UltraYellow
Sep 24, 2015 05:41 AM
Bigsyke
Sep 11, 2015 06:19 PM
Inspatatrac
Sep 8, 2015 02:12 PM
Darkspy
Sep 7, 2015 09:09 PM
