Question about my alignment specs
Old Sep 19, 2008 | 03:14 PM
sk26dett's Avatar
sk26dett
Default Question about my alignment specs
Hey, i just got my alignment done because my car felt unstable over bumps, kind of like it's bump steering. After the alignment it feels the same but they said it's all within spec. The spec are:
Front(L/R)
Caster: 8.7, 8.5
Camber: -0.8, -0.9
Toe: 0.05, 0.05
Total Toe: 0.10
Rear(L/R)
Camber: -1.4, -1.3
Toe: 0.1, 0.1
Thrust Angle: 0.0
Are those specs okay? Right now I'm on stock springs and shocks, but i have my hotchkis sway bars still in set to hard front, med rear. Could they be causing the bump steer/ wobble? My tires are pretty old but have been balanced recently and there's no other vibrations or shakes when i drive. What else can it be? Could it be caused by bad shocks, they are the original 03 shocks and i think they're bad. Any input is appreciated! Thanks
Old Sep 21, 2008 | 12:34 PM
sk26dett's Avatar
sk26dett
bump for some help!
Old Sep 22, 2008 | 05:58 AM
pascal's Avatar
pascal
Hotchkis sway bars:
F 48% (2nd hole) R Med (125%)
Hard Front (4th hole) are for tracks only.
Camber F -1.30 R -2
Enjoy!
350Z 2003 - ATI supercharged 450bhp 8psi - Hotchkis sway bars - Axxis wheels 20 - Unorthodox pullies - clutch, flywheel.....Stop Tech aero brakes...
Old Sep 24, 2008 | 04:30 PM
ladyzed's Avatar
ladyzed
The alignment specs seem to be within Min & Max specs, however, caster on the left is near max specs - but I doubt that's causing the bump steer.
I would blame the settings on the bars.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
