clutch line bleeding
ok i have read the few searches that came up, i have tried to gravity bleed, pump bleed, gravity and pump bleed. pressure bleed, and still nothing. i installed a stainless steel line. i have pumped the pedal so much i have blisters all over my hands. what else can i do here because i have never had this much trouble with a clutch line before?
ok finally had to feed fluid thru the bleeder valve with a food injector with some hose shoved on it. then bleeding it after a few times. works great now.
