Car wont start! Grinding noise????
Old Oct 28, 2008 | 06:08 AM
djtimodj's Avatar
djtimodj
Default Car wont start! Grinding noise????
Over the past few weeks my car has started to grind sometimes when i try to start it, the noise is the same as if you were to have your car running and turn the key to start it again. Sound like the starter motor hitting the flywheel teeth?
I have a JWT clutch and flywheel as well. the only way it will start is if i put it in gear and rock the car back and forward to turn the engine over and then it starts as normal?
Any one have this problem or no how much a starter motor bedix is??
Thanks guys.
Old Oct 28, 2008 | 06:13 AM
Tac-M's Avatar
Tac-M
I have the same problem. what helps is turning off ignition - all the way off, and starting it again.
i have replaced the starter, but the problem is still there. it is JWT flywheel.
It does not happen every time, so I am living with it.
Old Oct 28, 2008 | 06:41 AM
Tac-M's Avatar
Tac-M
I just e-mailed JWT, let’s see what they know about this.
Old Oct 28, 2008 | 06:54 AM
djtimodj's Avatar
djtimodj
My car when it grinds when i try to start it even if i turn the ignition off totally is just grinds untill i put it in gear and rock the car to move the flywheel! Like you said its happened 3-5 times in may be 50 starts so far but ive had the flywheel on for months but only the past few weeks its started to do this.
Old Oct 28, 2008 | 10:00 AM
ADMAN's Avatar
ADMAN
Sounds like the starter and flywheel are not lined up. Or, they are TOO lined up and the starter is getting stuck on the flywheel.
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
AbyteZero
Sep 22, 2015 09:17 AM
Daniel_dh
Sep 7, 2015 12:56 PM
