Starter issues?
Old Oct 28, 2008 | 04:55 PM
charged's Avatar
charged
Default Starter issues?
When I start my car on occation it makes the sound that a car makes when you try to start it when it's on. What is cusing this and how to fix issue?
Old Nov 3, 2008 | 11:16 PM
mastercater7's Avatar
mastercater7
Dont hold the key for a long time in the start position or replace the starter
Old Nov 4, 2008 | 02:04 AM
djtimodj's Avatar
djtimodj
My car does it too sometimes, Could be the throw out gear getting dirty or stuck or worse case missing teath on the flywheel! My car seams to have just sorted its self out! yeay!
Old Nov 22, 2008 | 04:51 AM
charged's Avatar
charged
Originally Posted by SMarinoZR
It sounds like your clutch travel needs to be adjusted. With the aftermarket clutches it's important to have a proper clutch disengagement point. Next time it grinds, stop cranking the engine, bring the clutch pedal back up and push it down as far it will go. Restart the car and the starter grinding should have stopped and the engine should start.
Mine did that after a JWT clutch/flywheel install and making sure the pedal is completely down on the floor before engaging the starter is the quick solution. The best solution is to readjust the clutch master cylinder stroke. Mine was out from factory spec and it was just another finely completed job from a Nissan master mechanic that needed to be corrected.
THANKS!!
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
