What PSI do you use on stock 17s for 03
Old Nov 11, 2008 | 03:33 AM
inittab's Avatar
inittab
Default What PSI do you use on stock 17s for 03
What tire pressure do you use on Stock 17s on your 03?
The tire pressure guide in the car says to use 35 PSI but I have found that caused my rears to howl around 80mph, so I use 32 PSI all around.
Old Nov 11, 2008 | 08:29 AM
DavesZ#3's Avatar
DavesZ#3
Most people follow the recommended 35 psi. I can't imagine any reason that the correct pressure would cause your rear tires to howl then stop because you lowered it a little.
Old Nov 11, 2008 | 09:29 AM
ADMAN's Avatar
ADMAN
I used to run 38 in the front - 34 in the back. But, temps are are little hotter here.
apex locator
Jul 23, 2021 02:27 AM
