Removing Driver Door Glass - HOW?
My driver side window motor died. I tried the cleaning trick, it didn't work.
So I ordered a new track and motor. The other problem though is, the window is in the down position. I can't get it to go back up. How do I remove the sucker, so I can install the new component's and get this thing running again?
https://my350z.com/forum/maintenance...dow-motor.html
You should try to search it before start the new thread anyways good luck on your new windows motor.
I just had to change my driver side window motor and all you have to do is remove the window motor cover ( three screws ) and then manually turn the motor armature to raise the window to the upmost ( closed ) position and then follow the directions in the window motor repair thread and replace the window motor.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
