Transmission and rear suspension problems!!! HELP PLEASE!!!
Old Nov 27, 2008 | 06:35 PM
ddongman's Avatar
ddongman
Default Transmission and rear suspension problems!!! HELP PLEASE!!!
i own a 08 base model with only about 14k miles on it. i think there is a transmission problem, because every time i put the car in gear and drive it sounds fine. but right when i take the car out of gear and into neutral and depress the clutch, the engine or transmission makes a clanking noise. i dont really know how to describe the noise, but it sounds like something under the hood is gargling screws.
and the suspension problem is every time i go over a slight bump or anything on my right rear axle, there is this clanking or rubbing noise. it sounds like two pieces of metal are clanking together.
i understand that my car is still under warranty, but i also know they hate working on cars, so does any one think they could help me?
any help would be deeply appreciated!!!!
Old Nov 27, 2008 | 06:44 PM
Beka Z's Avatar
Beka Z
take it to the dealership... in the earlier year models... yes the clutch/flywheel will sound like a box of marbles... if you press the clutch in, it will go quiet. this is a common trait of the Z; also the clunking when in and out of gear at a stop...if you are in the brand new GTR you will still hear a clunk when coming to a stop!.... but only you will know what is TOO much. As for your rear axle "click" take it to the dealer this was a TSB/warranty issue on previous models...
so bottom line - even if you don't want to - take it since you are still under warranty or you may end up regretting it if not.
Old Dec 3, 2008 | 01:54 PM
B1nKs's Avatar
B1nKs
Hey man I have a 2008 Enthusiast 6MT with only about 5500-5600 miles on it and i know what you're talking about with the rear axle deal. I thought it was my exhaust(i got the Bassani) was loose hitting some cross member or something. Maybe it is the suspension I don't know but when I'm going down the highway(which is sh**y here) for a little while I will hear the clunking. Let me know if you take it into the stealership if they help you or not ! GL
Old Dec 3, 2008 | 01:56 PM
0jiggy0's Avatar
0jiggy0
i have the same metallic *clunk* from the left rear over moderate+ bumps. guess ill take it in sometime soon.
burglapfd
Dec 6, 2020 01:04 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
