No Crank, fine 5 minutes before
Old Dec 2, 2008 | 07:03 AM
Sol@rZ's Avatar
Sol@rZ
Default No Crank, fine 5 minutes before
My 05 350z (automatic) (which was running fine 5 minutes before) wont start. Or even try to start. However, I do have headlights, wipers and radio. I have checked fuses, battery and gas level. I checked the inhibitor switch fuses, and battery current and everything is fine.
When I connect the starter directly to the solenoid, it started right up. ( I don't want to crawl under my car each time to try to start it) I’m thinking that its some sort or sensor, but I’m not sure which one. Anyone know what might be causing this problem? A friend of mine was thinking that maybe there is a loose wire somewhere.
apex locator
Jul 23, 2021 02:27 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
