Need Help. Knock after Royal Purple Oil Change
Old Dec 15, 2008 | 08:22 AM
wrxboy08's Avatar
wrxboy08
Default Knock after Royal Purple Oil Change w/video website link
Hey i don't know if this is the right place to post this so tell me if its not. This is my first post for the site. I have owned my 05 z for about 6 months now. I recently changed my oil and rear diff fluids to Royal Purple 10w30 in engine and 75w90. I noticed that i now have a slight tick/knock in the engine. What is this. Did i do something wrong. Is it too late to switch back. Please give answers fast because this is my daily driver. Im new to 350zs. I have always worked with Subarus. Thanks
vid website:
http://media.putfile.com/350z-engine-knocking-
This is not my video but is the same knock
Last edited by wrxboy08; Dec 16, 2008 at 08:00 AM. Reason: found a video with same knock
Old Dec 15, 2008 | 08:25 AM
Note for future reference:
Put a subject in the subject line not “help me!”
Double threads are annoying.
Old Dec 15, 2008 | 09:45 AM
j.arnaldo's Avatar
j.arnaldo
Does an oil change have anything to do with the engine knocking/pinging? I thought it had to do with gas octane ratings.
Old Dec 16, 2008 | 07:37 AM
wrxboy08's Avatar
wrxboy08
bump for more answers
Old Dec 16, 2008 | 11:00 AM
j1234's Avatar
j1234
mine is doing the exact same thing. nissan tech told me its the oil filter i was using. didnt have the check valve to prevent drainback on the amsoil filter i was using. switched to K&N with the check valve and does the same thing still. driving me nuts. i checked last night, sound is coming from the exact same location, same frequency and timing as the video. i used a long flat head screwdriver to figure out the source of the knocking. the valve cover area sounds fine, if you place the screwdriver on the ID plate just above the exhaust manifold you can hear the knock.
according to the maintenance manual this would indicate either piston slap or rod knock. Nissan tech told me it was the lifters becoming unprimed because i wasnt using a nissan oil filter with the check valve. also told me to put a nissan filter in, and after about 2 oil changes it should go away. when i asked him if it would do any damage he said it shouldnt and is a very common problem with the VQs when people take them to the quicky oil change places. ive now gone over 2000miles on my car since i first heard the noise. car still runs fine, no smoking, slightly rough idle with the AC off, which is normal for the Z. its just a sound right now and hasnt gotten any worse.
Old Dec 16, 2008 | 01:08 PM
wrxboy08's Avatar
wrxboy08
thanks abunch. let me know if anything else happens or if you find out how to fix it
Old Dec 17, 2008 | 07:58 AM
wrxboy08's Avatar
wrxboy08
bump for needed answers
Old Dec 18, 2008 | 01:55 PM
NightRider88's Avatar
NightRider88
Default I use Royol Purple Constintly
I have about 20,000 miles or more on my 08 nismo....change/changed the oil every 3000 miles....i have always used royol purple since my first oil change...and always use the k&n oil filter.....and i dont even have this problem....
Old Dec 19, 2008 | 11:07 AM
RedBullRR's Avatar
RedBullRR
Try using the proper Oil viscosity 5W30 as per the owners manual.
Old Dec 19, 2008 | 11:33 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
vid website:
Get rid of the crap RP out of your engine and put some Amsoil or Penzoil Plat that actually protect your engine. RP is one of the worse synthetics you can get on UOAs.
Old Dec 19, 2008 | 02:26 PM
tunedby's Avatar
tunedby
if this is so focking annoying you then don't even care.
you pissed about everything WTF wrong?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
