bogus tire pressure warning during trip
Old Aug 25, 2003 | 08:09 AM
WayneTN's Avatar
WayneTN
Default bogus tire pressure warning during trip
Took my Z down to Fla. last week and started out with about 39 psi in each tire. (I had added a little extra pressure to hopefully help with the gradual tire feathering problem.) After about 30 min. on the interstate the tire pressures had come up to 41 psi. (The tire pressure monitors and my electronic gauge were in pretty close agreement.) At this pressure, though, the low tire pressure light came on.
I pulled off of the interstate and verified that I had good pressure in each tire - about 41 psi. But, thinking that 41 may be slightly higher than the computer wanted to see, I let about 2 psi out of each wheel, down to 39 psi.
Back on the interstate, the tires once again built up to 41 psi and the light came back on. Knowing that there was no real problem, I went to Fla. and back with the light on. Each time I stopped, the tires cooled, the light went out, but then came back on when the tires heated up.
Does everyone have this problem: the warning coming on at interstate speeds?
tia,
WayneTN
Old Aug 25, 2003 | 09:07 PM
lam's Avatar
lam
hi ! body
i have the same problem too. i plan to bring it to dealer tomorro to check out
my car with 19 by 8 1/2 front & 19 by 9 1/2 rear 5zigen 5ZR back chome. i have this probem after i put the wheel on i let you know soon see what wrong with that
Old Aug 26, 2003 | 04:14 PM
lam's Avatar
lam
hi i just went to nissan dealer this morrning they tell me the problem is because of my tire is low profile to fit it i need to put the factory back on
i know they going to say that man
so let me know do you have the aftermarket wheel on your car or not.
Old Aug 26, 2003 | 05:56 PM
WayneTN's Avatar
WayneTN
No, I just have the stock 18" wheels that come on the Performance and 6MT Touring models.
Hope you get your problems worked out. You may decide to keep the aftermarket wheels and not use the presure monitors.
Wayne
Old Aug 28, 2003 | 07:41 PM
lam's Avatar
lam
when ever you fix you problem would you mind to let me know what cause it's?
Old Aug 29, 2003 | 10:05 PM
nlauri's Avatar
nlauri
Mine came on today in garage at a cold start said I had 27 psi but tire gauges (used 2 different ones) said 35psi just like they are supposed to have. While driving the sensors went up to 31. I have stock tires/wheels for touring. So warning light won't go off and I will have to wait till after labor day to get same in to dealer. Hope they don't try to tell me it's my tint cuz I have had that for awhile and no problems. Any ideas?
Old Aug 29, 2003 | 10:36 PM
toykilla's Avatar
toykilla
i saw a TSB on the nissan site about this.. i printed it out and will taking mine in to get fixed next week
Old Sep 7, 2003 | 09:56 AM
Moodie's Avatar
Moodie
Minivan Racer
Default Do you have the TSB?
I went on a run last night for 2 hours, on the way back, the light came on. If anything, the tires are hot, so it should be higher on PSI. Went to bed, and this morning going to get some air for the tires and the light is gone.
Old Sep 7, 2003 | 10:00 AM
Moodie's Avatar
Moodie
Minivan Racer
Default Found the TSB in Resources....
Thanks!!
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
