Help, car shaking hard after valve cover gasket replaced
Old Dec 23, 2008 | 05:39 AM
cheatthe1's Avatar
cheatthe1
Default Help, car shaking hard after valve cover gasket replaced
I replaced the valve cover gasket last night and let the sealant set over night, came out to the car and start up seems fine except a hard shake and obvious tone from exhaust like it is cammed or something. Did i mess up the spark plugs and reverse a couple cylinders or what? please help, i have a lot to do today, dont feel safe driving car this way, and this is a huge problem...
Old Dec 23, 2008 | 05:59 AM
cheatthe1's Avatar
cheatthe1
k, i tried the spark plug wiring both ways with no results, also i have a Service Engine Soon light. Wish i has a code reader but i do not, and dont wish to drive car to find out what this is. Only other thought is i may have bumped loose a injector? Does this seem possible with my problem? thanks again
Old Dec 23, 2008 | 06:55 AM
cheatthe1's Avatar
cheatthe1
hot damn im good, guess it pays off to learn how this stuff works on your own. Was the injector, they were a little loose when i installed the stock ones back onto the previous injector harnesses. When re setting the valve cover in the dark i popped the back injector harness right off the injector. The noisy thumping i was getting was a cylinder not firing properly.
Hope this helps someone that runs into this down the road.
allmycarsdie
May 13, 2016 04:38 PM
May 12, 2016 07:42 PM
Vigman
Nov 17, 2015 04:34 AM
smithmt3
Sep 11, 2015 08:25 PM
Darkspy
Sep 7, 2015 09:09 PM
