psi light came on
Old Nov 21, 2008 | 08:13 AM
3-fifty-WeEe's Avatar
3-fifty-WeEe
Default psi light came on
need help.
so i was doing some intense drift action and my tire pressure light came on... psi blinks in the little multi gauge .. i cant figure out h9ow to turn it off... do i just need to add air to my tires?? they are all around 30-31 psi
it would be great if you guys could help
Old Nov 21, 2008 | 08:30 AM
WTX350Z's Avatar
WTX350Z
Originally Posted by 3-fifty-WeEe
need help.
increase them to 35 and drive it around a block or 2. I'm under the impression it will reset itself...but I could be wrong.
Old Nov 21, 2008 | 08:46 AM
Tim@WestCovinaNissan's Avatar
Fill up the tires, drive it and it will turn off. Set them to 35-36 when warm. 30-31 is too low.
Old Nov 22, 2008 | 05:22 AM
kof0127's Avatar
kof0127
Do you know how to reset the PSI light, i have the same problem with my Z.
It pop when I drive, and the light is on ever since.
Old Nov 22, 2008 | 07:47 AM
Refer to above post.
Old Nov 24, 2008 | 12:08 PM
3-fifty-WeEe
ya i fixed it up guys.. lights now off -- to fix the problem i just drove around to heat them up and came back home and put 38 in the fronts and 35 in the rears.. everything is good and the light shuts itself off when i started up the car again.
Old Dec 22, 2008 | 07:11 AM
ZRuggernDC's Avatar
ZRuggernDC
I cant get my light to go off. it isn't reading any pressure at all. Any suggestions?
Old Dec 22, 2008 | 08:59 AM
DavesZ#3's Avatar
DavesZ#3
I'm guessing your wheels don't have the TPMS in them, right?
This might help... https://my350z.com/forum/showthread....9&postcount=44
Old Dec 23, 2008 | 07:49 AM
SS728's Avatar
SS728
http://www.allfordmustangs.com/forum...rk-around.html
Problem solved.
Uriyo_
Sep 8, 2021 08:46 AM
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
