Stealership... Front driver strut bent?
Just had an idea! check too see if your front tires are actually on the front and backs are on the back...
someone might have rotated your tires for you, and if you have different sized tires from side to side, that will definitely cause a pull...
stock size should be 225's on front and 245's on back...
