Valve Cover Replacement: Gaskets or Silicone?
Old Jan 23, 2009 | 03:56 PM
590sxz's Avatar
590sxz
Default Valve Cover Replacement: Gaskets or Silicone?
I'm starting to get into routine maintenance on my '03 Z for the first time (valve covers leaking slightly). I was referring to my FSM and it says to use a bead of RTV silicone to replace the valve covers, and in some funky fashion no less ("First, apply it to engine longitudinal direction..."). It doesn't say anything about a gasket kit.
I'm used to working on older KA and SR motors, so using a Felpro gasket kit from Advance Auto is generally the norm for me.
My question is, what is the proper way of re-installing the valve covers, RTV or parts store gasket kits? Is it any different from the older engines?
Old Jan 23, 2009 | 06:27 PM
JETPILOT's Avatar
JETPILOT
There is a rubber molded o-ring gasket for the valve covers. You also need to use RTV in addtion to the rubber o-ring on the front of the valve covers per the service manual.
Old Jan 26, 2009 | 08:56 PM
590sxz's Avatar
590sxz
Thanks man. I took another look at the manual and I see exactly what you're talking about.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
ablaine
Nov 29, 2016 10:13 AM
