Brake Problems
Old Jan 27, 2009 | 05:34 AM
mari_jose69's Avatar
mari_jose69
Default Brake Problems
I just bought a 2006 350z and i noticed a shaking wil braking, so i went ahead and cut the rotors ..but the pads look new, so i did not replace them.
I put the rotors back on and BOOM the car still shakes while braking...can anyone help me on this.
Old Jan 27, 2009 | 05:44 AM
Z04's Avatar
Z04
Originally Posted by mari_jose69
...so i went ahead and cut the rotors ..
that is your problem right there.
Old Jan 27, 2009 | 05:55 AM
*ICE*'s Avatar
*ICE*
get new rotors
Old Jan 27, 2009 | 06:18 AM
Dozzi94's Avatar
Dozzi94
Alignment.
Old Jan 27, 2009 | 06:35 AM
mari_jose69
So your telling me cause i went and got the rotors cut at a midas...thats my problem???
I had the rotors measured and they fall in specs.
Old Jan 27, 2009 | 06:39 AM
mari_jose69
ALIGNMENT???...the car does not pull..it just shakes from the brake pedal while braking.
Old Jan 27, 2009 | 07:12 AM
Dozzi94's Avatar
Dozzi94
It could have to do with slight alignment issues. It might not be noticed in pulling, but in braking. Does it always shudder, or only on uneven surfaces or while turning?
In the past I've had cars with slight alignment issues where braking resulted in a shudder.
Old Jan 27, 2009 | 09:29 AM
mari_jose69
It shakes anytime you brake...the faster you go the faster the shake and the slower ...the slower the shake. Only when braking.
Old Jan 27, 2009 | 10:15 AM
Q45tech's Avatar
Q45tech
The FSM has a rotor maximum runout specification [usually less than 0.001"] as mounted. Do your rotor as mounted comply?
Uriyo_
Sep 8, 2021 08:46 AM
