My headlight keeps going out
Old Jan 27, 2009 | 03:31 PM
boostintt's Avatar
boostintt
Default My headlight keeps going out
One of my headlights keeps going out!! I turn my lights on and off and the headlight works again... So it's not the light bulb... Then what? Ballast? I have an 03
Old Jan 27, 2009 | 05:00 PM
boostintt's Avatar
boostintt
Anyone?
Old Jan 27, 2009 | 05:05 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Maybe it keeps going out because it found someone special.
(sorry. I've been snowed in all day)
Old Jan 27, 2009 | 05:06 PM
KornerCarver's Avatar
KornerCarver
You might try throwing in a new ballast. It could also be a loose wire. Other than that, I don't have a clue.
Old Jan 27, 2009 | 05:15 PM
KeithGT's Avatar
KeithGT
Refer to my post in this thread, youve prob got the same thing going on. If not, its free and worth a shot...
https://my350z.com/forum/maintenance...-help-2-a.html
Actaully, here ill just copy and paste my post...
I just had this issue myself. More than likely your bulbs arent burned out, but your HID ballist, which is attached to the bottom of your headlight, has water in it. Your ganna have to take your headlights off your car, take off the ballast and let them dry out. Since i have no sun or warm weather, i used a work lamp that gets hot and it worked great. Why you have you headlights out, do the oven trick, take them apart and re-seal them. Dry them out first, which was hopefully obvious.
Hope this helps!
Old Jan 27, 2009 | 06:55 PM
redman333's Avatar
redman333
You can take the ballast apart with a torx bit and dry it that way. You shouldn't have to stick the headlight in the oven. I had to do this to my 03 lights as well.
Old Jan 27, 2009 | 07:46 PM
boostintt's Avatar
boostintt
Thanks guys! I'll fix this tomorrow.
Old Jan 28, 2009 | 07:27 AM
KeithGT's Avatar
KeithGT
Ya if hes not getting condensation in the headlight, no point in re-sealing...
Old Jan 28, 2009 | 09:06 AM
boostintt's Avatar
boostintt
def no condensation inside the headlight.
Old Jan 29, 2009 | 07:23 AM
j.arnaldo's Avatar
j.arnaldo
Do they have a resistor (i.e. instead of or besides the ballast)?
Old Jan 29, 2009 | 07:34 AM
06blueZ's Avatar
06blueZ
resistors arn't used as ballasts for lamps that are over about 2 watts, so i dont think so...
Old Jan 29, 2009 | 07:44 AM
j.arnaldo's Avatar
j.arnaldo
Thanks, blue. I'm learning a lot 'bout some interesting topics here, dude!
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
