tranny fluid change
Old Feb 17, 2009 | 10:11 AM
Ilike350Z's Avatar
Ilike350Z
Default tranny fluid change
I have an 06 auto and have 31k miles now. The tranny fluid is due for a change, and im kinda thinking which to get drain/refill OR flush. Is flush really that necessary, and does AT have filter in it? if not then i'll probably just drain/refill, i'll buy Nissan J-matic fluids and have my trusted mechanic change it.
Old Feb 17, 2009 | 11:54 AM
Vader007's Avatar
Vader007
Yes get the flush, a drain and refill only gets about half the fluid, if that.
You will need 14 qts to do a total flush. Why do anything half ***.
Old Jul 22, 2010 | 08:32 AM
codek's Avatar
codek
14 qts?
Old Jul 22, 2010 | 09:09 AM
DavesZ#3's Avatar
DavesZ#3
FSM says 11 qts. He's probably including the extra three for flushing and throw away.
Old Jul 22, 2010 | 10:11 AM
2000atlanticgt's Avatar
2000atlanticgt
In my opinion there is no need to flush. I have seen flushes cause more problems than they have ever solved. Personaly if it was my car I would drain and refill (only going to get about 4 qts out of the pan when you drain it) every 30k and you will be just fine.
Old Jul 22, 2010 | 12:46 PM
DavesZ#3's Avatar
DavesZ#3
^^ Totally agree. Unless you've had problems with the trans and it NEEDS a flush, there's no point in doing it until the 60K-75K range. That's why the Maintenance book only specifies Inspection with no mention of replacement.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
