Anyone ever fix their BCM???
Old Feb 23, 2009 | 05:55 AM
Jes-Z's Avatar
Jes-Z
Default Anyone ever fix their BCM???
I'm having a problem with my Driver's side door. My window is stuck down, my door lock doesn't work, and when I do press the locks, my rear wiper goes off. LOL. It seems that all of those things are controlled by the Body Control Module next to the fuse box in the footwell. When I press the window button I hear a clicking sound from the BCM. Now, I know if I replace it, I have to have the key reset in order to turn on the car. I hope changing it out fixes the problem.
Old Feb 25, 2009 | 02:02 PM
Jes-Z's Avatar
Jes-Z
Bump for the beautiful Z stuck in the garage.
Old Feb 25, 2009 | 02:30 PM
DavesZ#3's Avatar
DavesZ#3
It's basically a computer in a box. There's not much you could fix on it, replacement IS your only hope. Unless you have a short somewhere else that is causing it to freak out....
Old Feb 25, 2009 | 02:46 PM
captj3's Avatar
captj3
It sounds like you have a short some place. I had a similar problem it messed with my power seats and the drivers window. They replaced the bcm twice and it didn't fix the problem. It turned out to be a pinched wire under the drivers seat was shorting out. My old dealer in NY replaced the track and routed the wires wrong thus causing all the problems. Chek the car out first the bcm is probably in the range of 600-1000 dollars. I this helps you out.
Old Feb 25, 2009 | 07:33 PM
Jes-Z's Avatar
Jes-Z
Ouch! I'm going to try and wrap the cables as best as possible. Maybe tuck in whatever I can. thanks guys.
Uriyo_
Sep 8, 2021 08:46 AM
Cashwin
Oct 1, 2015 06:36 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
