Throttle Body Replacement
Old Mar 4, 2009 | 08:17 PM
RKnight's Avatar
RKnight
Default Throttle Body Replacement
How many have had to have their throttle Body replaced? I have a 04 and a few months ago I got a CEL. I have a friend with a high quality code reader and what he got was a faulty TB code. He cleared it but a few weeks later CEL again with the same fault code. I kept driving the car without clearing the code and the CEL went out on it's own after several days. Then one day after making a stop at the store my car would only run for a second and then die after starting. Tried about six times but it wouldn't stay running even if I gave it a little gas while cranking. Then I turned the ignition to the fully off position and then cranked it and it stayed running but with a CEL. Took it to the dealership and they said the entire TB needed replacing because either a sensor or the electronics that operates the butterfly valve isn't servicable. They said it is a common problem, in fact they had a new TB in stock when they first diagnosed my car but it ended up going to another customers car that was there before me so I had to wait a couple hours while they went to another dealership to get one.
Old Mar 10, 2009 | 02:56 PM
j3dz's Avatar
j3dz
hey man, i'm having the same problem right now...got the CEL (check engine light) on and i was told it was my TPS (throttle position sensor)...how much did the dealer quote you for this fix? thanks man
Old Oct 23, 2010 | 11:30 PM
Karenlee's Avatar
Karenlee
Default my first major repair.....
Stupid SES light comes on with the complimentary lovely limp mode. This happens a few times a week and I finally got tired of this crap. Took it into the dealer last week and they cleaned the throttle body and re-set all the systems.... you know the routine. With the P1239 code they said it may fail again into limp mode but at $800 just for the part I opted for just the service. Well, it went back to the dealer on a flatbed yesterday. They graciously only charged me for the part and no labour since they already charged me $250 a few days ago for the throttle body cleaning.
SHe runs better now.... plus they tightened down a loose motor mount for free which was my clunking sound in the front end I kept on hearing....
2007 Grand Touring with 30,000km.
Old Nov 28, 2010 | 01:38 AM
lenakance4life's Avatar
lenakance4life
just a quick question... was the dealer able to dsitinguish which throttle body it was based on the code off the obd?
i have the same issue and its due to aftermarket intakes... thanks
350z82
Oct 1, 2015 06:25 PM
