3 year mark - what to check/replace
Old Mar 11, 2009 | 09:10 AM
rockinbboy's Avatar
rockinbboy
Default 3 year mark - what to check/replace
Going to pulll a n00b on you but I rather ask the experts. Other than what the manual states, do you guys recommend anything to do/change/check for the 3 year mark? When should I change transmission fluid and diff oil under normal conditions?
Old Mar 13, 2009 | 12:25 PM
Bevo's Avatar
Bevo
At 30k miles, you should have your engine, transmission, differential, coolant oil, and air filter changed according to Nissan maintenance schedule.
Old May 9, 2009 | 06:54 AM
nyguy4u's Avatar
nyguy4u
isn't there a transmission oil filter in our cars as well? Not too sure. I have an 04' AT
Old May 11, 2009 | 07:40 PM
Zenica's Avatar
Zenica
Mine is an 05 with 16k, I was thinking of changing these fluid just based on the
passage of time, rather than miles.
Old May 18, 2009 | 01:24 PM
juelz86z3303's Avatar
juelz86z3303
leman's sunset 03 enth. model i have 120,456 counting .. should i have my timming belt replaced as well .. with the other fluids i usally flush.. wanted to do m timming chain for some time now im just curious if it should be replaced or tension adjustment should be the step.. .. im thinkingof really just replacing thanx . 03 leman sunset
jim wolf pop charger jimwolf stage 2 clutch and flywheel package ... cross and drilled slotted rotors... ss lines coming soon .. . plenum spacer... with the other goodies...
Old May 19, 2009 | 08:06 PM
danimaldaisy's Avatar
danimaldaisy
after 3 years i replaced all my endlinks....you can get all 4 from mynismo.com for like 60 bucks.
Old May 20, 2009 | 12:28 AM
aren21's Avatar
aren21
Im pretty sure the VQ has a timing chain, not belt.
Old May 20, 2009 | 01:21 AM
r_seng's Avatar
r_seng
Correct sir. Some SA at West Co Niss. tried to pull a fast one on me, telling that I need to replace my 'timing belt'... my reaction exactly
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
