Problems starting the car and it doesn't look like it's the battery?
Old Mar 28, 2009 | 05:14 AM
noodleman's Avatar
noodleman
Default Problems starting the car and it doesn't look like it's the battery?
Hey guys, I started having this weird problem with my car not starting.
The symptom looks like the battery is dead, in that when i try to start the engine, all the lights/electronics in the car shuts off and the car doesn't start. The voltage meter is saying the battery is around or just under 12V.
Here comes the weird part. I got out a volt meter to check the battery myself and it's around 12V, and even when I got another car to jump start it, the car will not start.
What I had to do was fettle with the fusebox/relay? thing that's in the battery area, and then the car would start, but it does sound like it's struggling to start sometimes.
Am i having some wiring problem, or the battery is actually dying?
Old Mar 28, 2009 | 06:54 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Sounds to me like you already found at least a possible problem. If you had to fiddle with the fusebox to get it started, you might either have a bad fuse or a bad connection somewhere.
AngryZ
East Canada
Sep 16, 2015 05:08 PM
PureR3d
Sep 10, 2015 06:23 PM
Darkspy
Sep 7, 2015 09:09 PM
Daniel_dh
Sep 7, 2015 12:56 PM
