Bad Crank Position Sensor?
Old Mar 31, 2009 | 07:51 PM
Duke52's Avatar
Duke52
Default Bad Crank Position Sensor?
Has anyone here done the ohm test on a crank sensor as the Nissan Service Manual describes? I believe I have a bad sensor but seem to have an intermittent result when testing the sensor.
When testing the resistance from terminals 1-2 and 1-3 it reacts as the manual suggests. When testing 2-3 it will sometimes not show any continuity but other times will.
Also I can't find one locally other then 4 or 5 days out from the dealer. Has anyone found one from somewhere other then the dealer?
Old Mar 31, 2009 | 09:33 PM
Duke52's Avatar
Duke52
After searching and searching I've found that the same sensor we use for our cars is also the same as several other Nissan applications including the 97 Pathfinder - which you can get at Advance Auto parts - the best part about it is the cost from Advance is $48 this is half the price of the dealer! I'll verify this tomorrow once they open and post my findings.
Old Apr 1, 2009 | 07:45 PM
Duke52's Avatar
Duke52
The sensor is not the same - one more reason to second guess some of the OEM part websites. I will have the correct part number and post it shortly.
Old Apr 8, 2009 | 09:58 AM
ADMAN's Avatar
ADMAN
I did not test. I just replaced.
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
