Front compression/radius rod replacement help
Old May 8, 2009 | 08:09 AM
antifreze's Avatar
antifreze
Default Front compression/radius rod replacement help
Again, another thing wrong with my 04 Z. The bushings on them are shot and i really need them replaced. The dealer quoted me at $600 parts and labor to replace both of them. Shops had no idea what I was talking about but would 'research it'. That makes me nervous.
Are these something I can do relatively easy? Anyone have a general guide or advice on the difficulty of this?
any help is appreciated.
thanks.
Old May 9, 2009 | 03:24 PM
Z&G's Parts Dis's Avatar
Z&G's Parts Dis
Vendor - Former Vendor
use this link to find the name of your part
http://www.courtesyparts.com/betasit...c-714_715.html
PM me your info:
Make:
Model:
Trim:
Year:
Part name:
and Ill give you a quote on monday
I sell parts from wreckyards
Install is straight forward even if you are slightly mechanically inclined. Main thing you will need is a breaker bar, a socket set, n PB Blaster spray lubricant.
Old May 9, 2009 | 04:34 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the rods are not particularly difficult to change with a factory service manual - they also aren't all that expensive to replace either
for the inner bushings which are the ones that tend to tear, we have the Whiteline ones coming back into stock hopefully soon
http://www.z1auto.com/prodmore.asp?m...ng&prodid=3783
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Dymsi
Sep 29, 2015 11:32 AM
samansharif
Sep 25, 2015 12:31 PM
