Complete tune up
Old May 13, 2009 | 04:40 AM
03350ZVA's Avatar
03350ZVA
Default Complete tune up
I was thinking about doing a complete tune up on my Z. This will be my first one. Can someone tell me what else I need to do other then replacing the spark plugs and wires. Also what spark plugs should I get.
thanks.
Old May 13, 2009 | 04:47 AM
johns350's Avatar
johns350
How many miles do you have on it?
Old May 13, 2009 | 05:05 AM
Z04's Avatar
Z04
thanks.
read your odometer, then look in your owner manual or check out the maintenance schedule. also avoid doing any unecessary maintenace and learn something about your car before attempting to do anything to it.
wires
Old May 13, 2009 | 05:06 AM
PerfZ's Avatar
PerfZ
Spark plugs are good for 100k - platinum tips. No wires - there is a coil pack for each plug. Not sure what else you would need to do - air filter and regular oil changes are about it for
"tune-up". See owners manual for 30/60,000 mile service but don't pay the dealer to do all that - most of it is "inspect" and no real work other than some fluid changes.
Old May 13, 2009 | 07:23 AM
Chasecbc's Avatar
Chasecbc
i changed my spark plugs @ 80k miles, they are pretty cheap so why not just do them
Old May 13, 2009 | 07:35 AM
raf84ny's Avatar
raf84ny
I changed my spark plugs @ 30 k and they looked OK. Glad I replaced them. I got the NGK Iradium IX for NA application. GL
Old May 13, 2009 | 09:51 AM
03350ZVA's Avatar
03350ZVA
thanks. The car just hit 70K. So its just the standard tune ups. I'll be doing it myself. Also Oil is change every 3k miles.
Old May 19, 2009 | 08:14 PM
danimaldaisy's Avatar
danimaldaisy
if you are at 90k (dont wait till 100k) swap the spark plugs.
otherwise....not much to do for a tune up.
1. clean the K&N
2. Clean the MAF
3. use some prestone (fuel injector ONLY yellow bottle 2.99 at walmart) --you DONT need complete fuel system cleaner
The Z has no fuel filter by the way.
That's it!!!!
i suggest using dielectric grease on the top part of the spark plugs..... the part where the coil pack makes a connection and also on the battery terminals....the car will run much smoother.
I had a 2000 acura integra that after doing a tuneup was smooth but just wasn't THAT smooth....using the electrical grease on the sparkplugs where the boots connect and on the cap made the engine actually run whisper quiet...it took me by surprise....worked on the Z like a charm....just use a tiny amount otherwise you will be hurting more than helping.
Old May 25, 2009 | 02:50 PM
03aeroZ's Avatar
03aeroZ
Is there a write up on cleaning the MAF? I know how to do it on most cars, but don't want to jack anything up if there is a special way to do it on the Z. Use electric cleaner also right? Not carb cleaner?
350z82
Oct 1, 2015 06:25 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
